Old canning rack - fix it up or leave it alone?
n8n
Curtis Bay, MD
Good morning,
I found an old pressure canner in the thrift store a few days ago, and I'd wanted one anyway. The metal looks fine and after replacing the gasket, regulator, and the little air vent I took it for a "dry" run (actually full of water and steam) and it works fine. However, the jar rack has some rusty spots on it, nothing bad just cosmetic. If I were to paint it with cold galvanizing would that be OK or since this is used with food would it be better to leave it alone? My **** retentiveness wants it to look nice and the canner will probably end up getting polished at some point. Can't buy a new rack like this, this is wire with handles, the ones sold today as replacement parts are more like trivets. Personally I would have made it out of stainless but then again I doubt anyone thought this would still be in service 70 or whatever years later (that's a guess, without going down a rabbit hole of research. It's a Presto model 7-B and apparently predates Presto using date codes. My housemate actually has an identical National model 7 with wood handles instead of Bakelite, which I guess means it's pre-1939 because of the name on the tag. Pretty cool, although at this point I don't trust the gauge on that one LOL.)
PCustoms
VT
I wouldn't put paint, cold galvanizing or any other solvent based materials in something that would be immersed in boiling water or near food.
Monza Harry
Windsor ON
n8n, you could consider ceramic coating it, the "silver " "Jet Hot" should look like a reasonable facsimile of the original. Also available is some high heat/temperature powder coat in chrome like finishes. The GJ way would be to recreate from polished SS wire. Just some ideas to mull about. Harry
