Hi all,
I picked up an old old Delta drill press a couple years ago, now I really need a working press as I have a few metal fabrication projects going on. The old Bosch rechargeable wont hack it anymore.
The press was really crusty, all the gears and mechanisms were gummed up. I took it mostly apart and cleaned it up, its working pretty well now, except the motor is dead. Even if it worked the old electrics are
The throat is labelled "A.R. Williams Toronto, Canada" and has an old Delta cover on it. The motor was a 115v 1Phase Frame 36 (!?!?!?!?!?!) 1/2 horse Leland made in Guelph about 15 minutes from my house.
The chuck runs true, which is awesome considering the condition.
Now here is where I need some help please;
The old is labelled "36 Frame" which doesn't correspond to any NEMA spec I can find.
The shaft is 3/4" keyed and staked with an allen bolt.
The "D" dimension from NEMA drawings is 4 1/8".
I cannot find a NEMA chart that lists a 36 frame.
I would like to keep the base-to-shaft-center and the shaft diameter the same, as I would like to reuse the pulley and the belts I have. If I have to I could turn the pulley out to 7/8" or 1" on a lathe. If I have to have a larger base-to-shaft-center (NEMA D specification) I will have to experiment with more belts.
I would love a recommendation for a replacement motor. I value a solid, reliable tool and something that belongs on a vintage tool is a plus. I have other Baldor motors and have had great luck with them on the compressor and lifts.
NEMA frame tables I have found show the only 3/4 shaft frames are 66, 203 and 204. The latter 2 are discontinued and I cant find any suitable 66 sizes from Baldor or anyone else I know of.
I am thinking 1/2 hp up to 1 hp. RPM is 1725. Reversible, with an "onboard" starter if necessary. I have a 240v welding outlet available if necessary.
Any suggestions?
Thanks
Any suggestions?
Thanks
