Old Drill Press Restore
bent valves
New England
I found a drill press that had been posted on Craigslist for months. There was no picture and no description other that it had a 1/2 inch chuck. Not much to go on but it was priced at $60 which made me curious. I called and found out it was a floor standing antique. So off I went.
It was a well used 17 inch Rockwell from the early 1950's and looked like it had been dipped in chocolate syrup from the cutting fluid stains. It also had a 3 phase motor. The table had the "smile of shame" from holes drilled too deep. But still, the price was right!
The first thing started on was the damaged table. Here is a shot of the "smile" filled with scrap bolts after tapping and Loctite. Some of the shallow divots were filled with JB Weld.
And the after shot.
Because of the 3 phase motor my choices were to change to a single phase or add a VFD (variable frequency drive). The VFD will allow both forward and reverse direction and an easy way to adjust speed. In this photo there is a switch (FWD- OFF- REV) and pot to adjust speed at the front. I used a Teco VFD for the 1 HP motor and this was less expensive that a single phase motor.
Here is a overall shot of the drill press. I have since modified the casters on the base to make it more stable. I have about $200 into this. for paint, casters, the VFD and this including the cost of the drill press.
Joe B.
That is a neat way of fixing the smile of shame. What did you use to grind off the bolts after you ran then in? How did you get the whole thing smooth?
I agree with being scared by the casters. Maybe you could make some arms that fold out and keep it level like you see on a crane.
bent valves
New England
I realized early on that stability was a problem with the casters. I added metal to bring the casters out from the base so now they form a triangle point of contact about a foot behind and to the sides and front. With the added footprint it is difficult to tip but I still will watch it. The reason for the casters is because of the limited space I have. All my tools are on mobile bases except for a heavy lathe.
After the bolts in the table were set I used a mill to machine them down close to the surface. Then a random orbit sander to get them flush.
