Old electric motor ?
aka rotten
Problem I,m having is old Homecraft bandsaw motor started to act up on me today by running few min,mabee 15 then waver a bit then shutoff.Few min. go by little pop noise then motor would restart for another bit of time.Not an electrician by any means.Is this new motor time, if so what do I need to look for? Saw itself is 49-0r 50 model.If help motor info as follows,DAYTON ACME CO.DACO MOTOR,Type,ace,cycle,60.H.p,1/8,volts115,1725,rpm.Thanks
A
aka rotten
Thought about as much,Does the specks on moter need to be exact or can someone tell me what to look for for old bandsaw please.Thanks again.
Rookie2
Western Pa.
1) voltage 2) rpm 3) mounting base 4)hp 5) rotation 6) shaft diameter and length
I would try a local motor repair shop to see if it can be repaired or if they have one someone didn't return for.
LS6 Tommy
Northern NJ
That "POP" noise is probably a thermal overload resetting. When was the last time it was cleaned/lubed? What's the amp draw as compared to the FLA rating?
Tommy
BFBOB
Disassemble, clean, freshen connections, lube and reassemble. Then see how it works. You may find something obvious like dragging armature due to worn bearings. If no change, no obvious defect, then see advice above.
A
aka rotten
Tommy
b
Be honest with you folks,in 30 some years I owned this saw ive never took apart motor.Keep saw part of it cleaned and lubed.Never new about servicing motor,i will try above sugestions before I get another,Thanks
James-W
Southeastern Wisconsin
If the motor is driving the saw with a belt, I would forget about trying to repair it and just get a different motor. You can probably go to an appliance dealer and buy a 1/3 hp used motor out of an old junk Maytag washing machine for about $10 or so. We used to sell them all the time when I was working at an appliance dealer.
Freejack
St. Peters MO
Yep, as prior posts have indicated, the motor was tripping the automatic thermal overload and the pop sound was the bi-metal disc (inside the interal overload protector) cooling down enough to pop back into shape and closing the connection.
That just means the motor was overheating and given the age, it's likely just packed with sawdust, I would just blow it out and see if you can make it run again.
Jake
A
aka rotten
Thanks for info gents, figured what the heck and took motor apart and was shocked. Everything from sawdust ,mouse nest[ripped apart] and a darn old 1957 series dollar bill with corner ripped off. Let run for 1/2 hour then cut some more wood pieces. Thanks again.
