RUMBLON
PORCELAIN LIGHTS QUESTION
I need some help and am wondering if anyone on here has the electrical knowledge to help me. I am attempting to restore/ rewire approx 10 of these old porcelain lights that are probably considered industrial because of their size- 18 hoods. Here is one intact. These are going into my 500 sq ft shed side thats attached to my shop on my 175 acres. Im going for the industrial look to say the least. I have been saving these for years and really want to use them and am assuming if I cant use these parts then I can find updates inners.
The shades unscrew from the shape top base. Underneath is the porcelain white lamp portion. This portion is a lot larger than a standard insert for the bulb.
However the white porcelain fixture can unscrew showing its larger size and inside that portion that unscrews it appears that a standard size bulb can screw in. this fixture had a broken bulb in it. I cant get the small metal inside out so I am GUESSING that the porcelain screw inert portion was parts of the bulb? not sure.
the other pieces are held in by screws and come apart. These have the cloth wire so I am going to rebuild them. My question is does anyone know if or where I can purchase larger bulbs that will screw directly in or where I can find the smaller piece that has these types of bulbs? Anyone have any experience with these?
I cant seem to find a supplier on line and a search of LOWES AND Home Depot show nothing in either store.
Curious if anyone has any ideas on what to use, restoring these or using something totally different?
This is the size compared to a standard size bulb
