Old IR type 30 compressors?
slackdaddy1
Southern MD
I know the newer IR compressors are ****,, what about the older units?
I am looking at an older T-30 5HP unit
hat pumps did they use? can you get parts
Thanks,
Nick
bob15
Northeasten, CT
I zero issues with my T-30. And it too, is an oldie. nothing wrong with the old IR's, they are pretty much bulletproof.
Packard V8
Spokane, WA
The photo you're showing is not even an old IR T-30. They've been doing industrial work for longer than most GJers have been alive.
Yes, you can get parts.
jack vines
S
slackdaddy1
Southern MD
So I picked it up - 200.00 because the motor sparked and smoked, the tank is in great shape. But a couple questions.
it is a model # 2340l5.230
I can not find specs on the OEM motor, the current motor is a Baldor 5hp 3450 rpm 21 amp. I suspect it is NOT the original motor? What specs I see on web sights is this is a 28 amp compressor.
Anyone have the specs on the motor? is it 3450 or 1750 rpm? clockwise or counter?
Also, I was supprised it is a SINGLE belt, not double.
Any insite would be appreciated
Thanks,
Slack
S
slackdaddy1
Southern MD
Checked the pulley sizes: motor - 6", pump 13.5"
So that is a factor of .444 x 3450 rpm = 1533 pump rpm
Man that is screaming,,,,
thinking about a 1750 motor and an 9" motor pulley = 1166 pump rpm??
Thoughts?
Slack
