Old Mechanics tester
Desertwind
This is marked ”Sunco Made In USA” It has 2 fuses inside. It looks like a pencil but I’m thinking to possibly test spark plugs. It says one tube lit weak. Both tubes lit strong with the word spark between. It’s in very good shape
considering it has to be quite old. I was wondering if it has any value. I am going
To be selling my deceased husband old tools But it’s a long processor my having to look Them up and try to estimate the prices so it’s going to be a while selling them. I’m also slow learning to use this site. I appreciate the help I have received from the members here so far. I did learn I can upload pictures but I can’t post them till I join a group which I’m going to be deciding which groups to join.
disston
Silver Spring, Md
Sounds like a spark tester. I'm not an expert on prices but I would think you'd only get a couple of dollars for one of those.
DesertWind,
You don't have to be a member of a group to post photos. Just follow these steps to attach photos from your own computer. It seems like a lot, but it's not. Once you do it a few times, you'll see that it's very simple.
- Below the white "Quick Reply" window below, hit the [Go Advanced] button.
- Then hit [Manage Attachments].
- Then hit [Browse] and find the photo on your computer.
- Select the photo and hit [Open].
- You can select up to seven photos. Then hit [Upload].
- Wait for them to upload. They will appear by file name .jpg under "Current Attachments".
- Hit [Close Window].
- Type your reply in the white space as you normally would and hit [Post Quick Reply].
Your post will appear and the photos will be thumbnails below it.
If you want them to be larger photos inside your reply, click on them in the "Attach Files" area under "Additional Options" below and copy the URL from the white URL bar up top and paste it into the post whereever you want it to appear, preceded by [ img ] (leaving no spaces between brackets and "img") and [ /img ] (leaving no spaces between brackets and "/img".)
