Old Napa Battery Charger Problem
Farmall 1066
Suburban Rockford, NE
My ancient Napa 85-140 battery charger has apparently died. On 12v low, it has about 9v output, 11.5 on hi and 12.8 on boost. 6v functions are all low also.
Has ampereage enough to spark nicely, and ammeter shows output, but voltage is low.
I can see AC voltage change at rectifier inputs as switch is turned, so I think switch and transformer are ok. Connections are all good, and nothing looks or smells burnt.
Can a rectifier fail partially? I'm at a loss as to what else this could be?
Warrenator
Newberg, OR
Might be some insulation has failed on the windings of the transformer, take a peek at the condition of that.
My old NAPA charger that came with the house had been left out in the rain, the alligator clamps were so corroded (rusty, just steel plated with copper) that they would heat up and smoke. Check the condition of all your wiring, high resistance would cause low voltage as well.
redmondjp
Redmond, WA
Yes, you could have lost one of the rectifiers. Do you have an AC voltmeter that you can use to check its output?
Infinia
SoCal
is that a selenium device ?
put a modern rectifier on it> at least something silicon.
added link
engineer2
Chicago burbs
When I was involved in that decades ago, failed rectifiers were the most common thing to replace. As said, check for AC in the output. An oscilloscope is the best way to check it.
