jamurr65
Started taking the pump apart and got to the centrifugal unloader and found a few warn parts. One of the weights has so much play in the pin hole it was hitting the case breather. I can probably fix that with weld and drill a new hole. But the piece on the end of the crank has deep divots in it from the weights hitting it all these years. I dont even know if that end on the crank is removable??? Also wondering why the centrifugal unloader housing looks so different from all the others I have been looking at on the Web.Is it because of its age???No label on the pump but the tank says 1966.
