Old Sears Floor Jack
scbeekeeper
I have an old Sears floor jack that I inherited from my father-in-law. The data plate lists it as a Sears product, model / sn EM 14909. I am unable to locate any information on this jack and was wondering if any in the group could help. I'm in need of a rebuild kit.
Thanks in advance for the assistance.
Great white
Looks like the identifier numbers are stamped in the arm. All I can make out is 727121 and then the rest isn't that visible.
That's your model number.
Go here: https://www.hcrcnow.com/shop/seal-kits/sears-craftsman?s=727
and you should be able to find a seal kit.
You may even see a PDF on the appropriate seal kit page and that will be the manual for the jack. I just checked he page for a 727.12100 and the owners manual (with parts breakdown) is there: https://www.hcrcnow.com/shop/seal-kits/product/3022
I have no affiliation with the seller other than have purchased a kit of them for my aluminum jack.
That should at least get you started on looking up info.
verify your numbers and check it out. Google will probably turn up more info with the model number.
Good luck
RAYJAY
UNION DALE PA
have the same jack here and think i have the manual here some place for it also
