Old sears table saw
Catadj78
Alabama
My stepmother called asking if I wanted her grandfathers table saw and sent these two pictures.
These are the only two pictures I have at the time and it looks like the extensions may be missing but I see it still has the fence and the mitre.
Anyone have any information on these? Like what year it was made? Something worth restoring you think? I'd love to restore it and make it the center piece of my woodworking area for the sentimental value.
I'm going to pick it up soon and will post more pictures
TomB19
Regina, SK, Canada
I can't help you with the year but I've seen plenty of these restored and they work and look great. I don't think it's particularly difficult. A little evaporust, paint, and some elbow grease and you will be proud of it.
I love heirloom tools.
The only down side is that it's likely a 9" saw. It's a bit harder to find 9" blades but they can be had and with two blades, you will be fixed for life. I have my blades sharpened every 5 years and I cut a lot. It's very manageable.
Sent from my Nexus 6 using Tapatalk
4Kings
Southwest Missouri
Google that part number. You'll see it pop up on Antique Machinery sites. Looks like most guys are dating that saw to the 30's
Packard V8
Spokane, WA
Don't worry about parts availability, as those saws are thick on the ground and essentially valueless. I've been given a couple of parts saws just to haul them away.
As long as the pot metal gears aren't broken, it's an easy restoration. Bearings are a common part number and the gears and tilt mechanism interchange between different table sizes.
The locking bolt on the front is not enough to hold everything perfectly square. I always add a matching locking bolt on the rear trunnion.
When looking for the table extension wings, be aware Sears sold saws with three different table lengths. Naturally, only the correct one matches up. The the extensions were also made in cast iron (most desirable), cast aluminum and stamped steel (least desirable).
Some came with motors as small as 1/3hp. The Craftsman brand motors with cast iron end bells in 3/4hp would be the best for that saw. Just make sure you use the correct drive pulley, as they're available in both 1750 and 3450 RPM.
I use a notched V-belt, as the driven pulley is quite small and a notched belt bends easier.
jack vines
C
Catadj78
Alabama
I googled the model number and seen various saws with various dates. Unable to confirm an exact date.
The extensions may be there when I go to pick it up. I'm pretty excited about and plan on doing a full restore on it when time permits. Luckily I have enough room it won't be too much in my way until then.
