threeputt
I own a shop that my dad built in 1961. Everything was run under the slap including air lines and of course water lines which are stopped up.
I have not turned the compressor on in about 15 years but it turns free and has oil in it. It was running the last time I had the power on.
My question is should I remove this compressor from the small building it in put in 50 plus years ago and put on the inside of the shop and just redo the lines. The info I found on the side of the unit is this
Kargard WP200 Build 1962 VA 5006G. I also noticed a Weaver plate on it but did not get the numbers from it.
It has a 5 HP Motor wired for three phase 220.
This compressor never failed me all the years I was in business. I have not used it more than a few hours since 1996 when I closed my shop and none in the last 15 years.
I drained the tank when I last used it but I can say it has not got any rust in it after sitting all these years.
I do work at the shop once in a while and when I do I just take my small compressor from home but it would be nice if I could get this old loud thing back going again. I know now why my dad put it in the outside building. You could not hear much when it was running and sure enough if was inside and close to where I was working
I thought it might be a good rebuild project if it would worth the trouble. What you think ??
