Old tile glue removal
sz0k30
I'm in the process of redoing my basement floor. Had a water pipe burst which soaked the carpet & foam pad. Had to get a flood remediation company to dry things out. Now I've decided to get rid of the carpet and pad and replace them with peel & stick tiles to avoid any such issues in the future. Most of the basement is bare cement with a section about 6' x 12' that was previously tiled. This tile was removed prior to the carpet install. The problem is there is glue and some sort of tile residue ? left.
My concern is the peel & stick tiles adhering to this residue. I bought primer for the cement as recommended, but I don't know if it will work on the previously tiled section.
I have tried to remove this glue & tile residue using:
1. heat gun - too slow, too small of an area & doesn't work
2. Commercial glue remover - odor chased me out of the house & way too
much scraping
3. Goo-b-gone - too much scraping
4. belt sander - too much fine dust and too slow
5. grinder with a wire cup wheel - no real effect
Any better ideas?:headscrat
Thanks.
HotRodKush
Beany-doo! I removed an entire basement of black tar cutback and tile residue with that stuff. Not toxic either, I think it's soy-based.
rsanter
visalia ca
I think a future flood can effect the stick down tiles as well.
I think you need ceramic tile or just grind and stain the concrete. Or even consider a quality epoxy job
How about polished concrete?
Bob
rlitman
Long Island
The answer to this with my previous company's warehouse that was getting epoxy was to shotblast the mastic off.
I'd get a scraper blade for an oscillating multitool, or sawzall.
stage20
pcola FL
Peel and stick tiles will turn gummy when wet...even in the basement if here is moisture. This will cause the tiles to cup at the edges overtime. I don't recommend them. A glued product either pressure sensitive or a hard set acrylic will last the time.
I used Sentinel 747.
Do an area about 2'x2'. Wet thoroughly. Let sit (read label). Scrape any "lumps". Wipe up with blue shop paper towels. I did the whole floor twice, but I don't think it was really required.
Wash. Rinse. Etch. Let dry at least 24 hours. PAINT. Basement laundry room. Looks new 5 years later.
