Old welders
jabberwoki
puyallup wa usa
Is it worth messing about with older welders?
DuluthMachineWorks
Duluth, GA
If you’ve got the space and the power, at that price, sure. It definitely won’t have the same feature set as a modern inverter- it’ll only be running 60Hz sine wave tig with no balance control in AC mode, but if most of what you want to weld is mild steel/stainless I’m sure it would lay down nice wells all day long.
Honestly that’s almost scrap price there, so it’s a steal if you have somewhere to put it and a way to move it
gearhead1
NC
Depends on what you want to do, how often you want to weld aluminum. It’ll weld aluminum, but the old machines are a power draw and don’t have as many adjustments as the new ones. If it’s local and you got the space and power, it is cheap.
For TIG, I bought a PrimeWeld, and has a lot of bells and whistles for the money taking up way less space and less power draw. Just a comparison.
Bondo
Greenfield, Maine
Ayuh,..... Do you have 3 phase power available to run it,..??
mike93lx
Richmond, VA
Kind of an odd question for a single phase welder...
To the OP, new inverter welders are fantastic. Lighter, less power draw, lots of features. I'd skip on a dinosaur.
Bondo
Greenfield, Maine
Ayuh,..... Forgive my ignorance, but in my world, 208/230/460v are 3 phase voltages,.....
86turbodsl
I have a 330a/bp also. Fantastic welder. ENORMOUS power. maxes out at something like 450A.
I didn't see the price on the ad, but i gave 300 for mine and felt like it was a very good deal.
I like that it can be repaired with a service manual and a voltmeter. No expensive boards to go bad.
It's SINE wave output though, and aluminum welding can be a little tricky to learn on SINE wave machines.
Full output requires about 105A 230V input. So it's a bit of a power hog. It's a 900lb welder though. It does well
if you just sit in a corner and not move it. the foot pedals are a bit rare and go for about 150-200 on the bay.
No bells and whistles. Runs an arc-air well and won't kill the machine.
I traded up to a syncrowave machine, but there's nothing wrong with a 330 and they will work forever. there's nothing
inside them to go wrong. If you want portable to take to a buddy's house, get an inverter and just pray a board doesn't go bad.
I kept my 330 as a backup machine because i know when the syncro loses a 500 dollar board, the 330 will work.
NDJ
BC, Canada
Be careful. Older AC TIG machines like that with HighFreq, May use some real hard to find high voltage Capacitors in the HF generation. Typically these caps deteriorate with age.
gorilla
I own that exact machine, I've welded everything from .032 SST to 1" aluminum plate with it. It is big and heavy but I think it's a good deal for that price.
