OldeDude2
drivesitfar
OD: welcome to the forum from a neighbor across the water. i don't have the Snappy answer for you, but might i suggest doing a search either in General tools section or do a google search and in most cases they will have a GJ link near or at the top to click on that might bring up some older threads that are not easily found on GJ's search engine.
good luck and if you do find threads talking about your Snap on and you don't find your answer ask a question on that thread where you have members talking about it instead of this intro thread where not many members even know it's here.
cheers
LB-1911
Northwestern Il.
I have a Snap-On valve adjusting tool V21A, but I cannot wrap my head around what valves it would be adjusting??
From a previous thread;
07-06-2008
SnapOn V21A. Any ideas on what it's used for??
07-06-2008
Valve adjustment. Mostly on GM 6 cylinders. The screwdriver tip on the tool was used to adjust the screw on the rocker arm. The 1/2" square is for the socket that you added on the tool, to loosen/tighten the nut.
Ideas on what this is used for??
http://www.garagejournal.com/forum/showthread.php?p=244664#post244664
:beer:
