Older Edsal shelving asssembly question
Planenutz
Central Minnesota
This isn't the usual Home Depot stuff, much heavier built that that.
I'm trying to set it up but for the life of me I can't figure out how the inverted V-shaped front to back support from the cross pieces goes in. The two in the picture I got in by much beating, swearing and bending. Pretty sure it's not supposed to be that way.
Anybody done these before?
BillK
Beautiful Southern Maryland
I have very similar racks at the shop but I dont think they have that type of cross supports. I will take a look in the AM. Some of that old school shelving does take some beating to get it together at times.
BillK
Mine have a different type of support. Wonder if you could widen the slots a little and make them a sloppier fit to get them in easier ? Mine have shallower supports that just sit on a ledge. Much simpler.
Skyking1992
I have some racks that look just like yours. I put the "V" shaped cross piece in on its side, then rotate it upright. I then use a rubber mallet to move it to the right location and square it up. It does make a lot of noise, but should go without too much force.
P
Planenutz
Central Minnesota
I got a reply back from Edsal and they said the exact same thing you said.
Bigger hammer and pry bar time!
Thanks all
