Oli Seal
coolguy
Rebuilding my Floor Jack (NORCO) Has anybody
tried to put a new Oil seal in one?If so what kind of trick did you use to install one. Thanks for your time fellows.
russlaferrera
Central Virginia
If it 's the Ram seal, you can wrap some shim stock around the seal, use a hose clamp to snug it up and push it into the bore.
The bore should have a chamfer on the end.
