Olsa Switchless ratchet wrenches
nichocha33
jumbojak
Surry, VA
They just look like clones of flat Gearwrench ratcheting wrenches to me. I'm sure they'd be fine but you can get the same thing under at least a hundred other brands.
eschoendorff
Interesting concept. I can imagine a lot of accidental switching with that kind of design though. Maybe take one for the team and let us know how it works for you?
jumbojak
Surry, VA
These are switchless reversible, you push on it and change directions
Ah, I had to look them up on Amazon to see how they were supposed to work. Seems to me like they would reverse easily in use, especially if you were in an odd position. Push "up" then beck and forth to change direction could cause problems but they might work very well. You won't know until toy try them out.
bonneyman
Desert SW
Craftsman had a ratcheting combo wrench that had a weird "push to release and reposition quick" feature that drove me crazy. Couldn't sell those things fast enough!
ChrisLS8
Sounds awful, you have to apply pressure to turn in a certain direction. Sounds like a worse solution to a problem that isn't a problem
Kasal
Galicia, España
I have a couple of games not of that brand, it is as easy as turning the key, they are comfortable at least for me.
BTJHP
TX
Anyone still using these Olsa branded Quichet wrenches? It sort of looks like Olsa isn't going to be importing them any longer.
BTJHP
TX
Only the SAE set is in stock. The best Black Friday deal from Olsa is probably the $20 roto ratchet in 1/2" drive.
fcyle10
They have the sae 8 piece set on their website for $30 bucks if you want to try them out first
ToolG
Not click type I think
these were the only ones ever made... discontinued now thoo
