OMG!!! There's a tool I don't have!!
ZRX61
Solar Blight Valley, SoCal
Swapped out the brass valve seat doodads & the washers on a couple of faucets. Removed the old & installed the new by using a flat screwdriver pushed into the valve seat... Thought to myself "Yanno, there's probably some spiffy tool for this..."
& it turns out there is:
http://www.greydock.com/hb-c1108.html?gclid=CM_P1sP9yswCFceCfgodsB4Kvw
Lowes has a pretty much identical set for $35.88 :(
http://www.lowes.com/pd_621975-1366-60929_0__?productId=50219489
BUT!! Now I know what they look like I shall keep an eye out at yard/estate sales :)
shoot summ
I've got an older set, L shaped, different sizes/shapes on each end.
SARG
Northeast
Sorry lads.... aint about your tools ....... it's about having ancient faucets.
Z
ZRX61
This house is about 30 years old & nothing has even been upgraded. My old place was twice as old & had ceramic spiffiness in the faucet dept. :thumbup:
I've been in the US for 25 years & still have the occasional "oh, so that's how they do it out here in the colonies" moment.
LXCam
Lowes also carries the multi step L shapes ones to for like $10.
A/C service guys use a tool similar to that that has a stubby hex/torx (?) for opening and closing service valves.
I have an "ancient" Craftsman 1/2" X 9/16" ratcheting double box end that looks almost identical.
shortykorte
Tallahassee, Fl
Plumbers tool definitely fall into the "using the right tool...."
Go to some pawn shops and look in tool boxes or assorted tool bins. Great place to find sets.
southalabama
Brewton AL
Plumbers seem to have a lot of specialty tools.
I've started buying them too and throwing in a "plumbing toolbox"
WhiskeyRanger
I remember the day I learned about the basin wrench. It did two things, it made faucet installation much easier, and it gave me one more reason to be come an electrician instead of a plumber. ;)
Roberts210
Missouri
I have an old square Nicholson file that has a square, tapered tang. I've used it for years to remove and install seats. Works great.
bmxdad
Puyallup, WA
House was built in 1910 or 1901, depending on what paper work you read, and power and water added in the 30's ... bought a seat tool when I bought the house.
If you let the old faucets drip, it'll erode the seat and tear the rubber seal making it drip more ... until it's a continuos flow. don't take long either ...
bob15
Northeasten, CT
This is a better style.....centers the cutting tool better:
http://www.amazon.com/LASCO-13-1065-Grinder-Reseater-Resurface/dp/B000FH6FT8
