Working on installing some cabinets and an on demand water heater. My first problem is I located the feed wire/box in the wrong spot. Or the cabinet didn't end up where I thought it would when I wired the garage.
Hopefully pics will explain better than 1000 words. There will be about a 3" gap between the wall and the back of the cabinet. Back of the cabinet is open, but was planning to enclose the backs of the cabinets. If I do that, the box with the feed wire will be behind the enclosed cabinet and not readily accessible. I left myself a whole 8" of extra wire in the box, so I must make a connection in the box. If I make the back of the cabinet removable, can I have that box hidden behind there? Even at that, it will be tight with the sink installed. If I do enclose all of that, can I run NMb from that box right into the back of the water heater?
Overall front view for reference.
Box location.
Second part of the question is about the heater itself. Doesn't it need some sort of strain relief where it comes into the heater housing? They just leave some knockout locations to use, but not familiar with what sort of wire clamp I can use on it.
Last question for this post..
Is there any restriction as to where I can locate this heater in the undercabinet area?
Box location.
