If you can't believe that is on youtube, you haven't spent much time on it
It just seems so crazy, and could kill someone. I thought I would share it.![]()
I don't see the big deal. What's so unsafe about it from a technical aspect if cord is sized correctly? Circuits have OC protection. The main thing I was surprised by was that the startup amps of the mill didn't trip the breakers.
Or the double ended male generator cords... you can buy those on Amazon.
https://www.amazon.com/dp/B07PDQ9QS2/?tag=atomicindus08-20
I was told those are called suicide cords!
use at risk of your own life!
or those life's around you!
That's not a suicide cord. Suicide code has a male plug on both ends.
That is exactly what was linked on Amazon.
One of the biggest issues I see is the wiring in the walls of most outlets is going to be either 14/2 or 12/2 and yes when running 220 current draw is lass then at 120 but most things that are 220 are high current draw. One reason why they run at 220. So if the breakers malfunction, I see some melty wires.
It "looks scary" Like an AR15 stock on a .22 rifle. Yes, it can kill someone if used incorrectly !I don't see the big deal. What's so unsafe about it from a technical aspect if cord is sized correctly?
Looks doesn't make something unsafe. There is really nothing unsafe about it as long as the OCP is sized for the wire. The other issue is if the 2 circuits are not on a 2 pole breaker, but those plugs serve as a disconnecting means from power.It "looks scary" Like an AR15 stock on a .22 rifle. Yes, it can kill someone if used incorrectly !
In order to create 220 don't the legs have to be 90 degrees out of phase. So if you only had 120 service you could not take two circuit breakers to create 220? correct?
Seems like to me with what he did it would of been possibly faster to go ahead and put in a 240/20 amp breaker and run it to his garage. All the stupid work he had to do to get it running was crazy and dangerous.
no
the sum needs to be 360°.
its also not 220v in the US.... 120/240v
If one only has 120v service, then they arent getting 240v potential no matter how many breakers they use....
I don't see the hazard. Only hazard I see is teaching an ignorant person this trick. The old saying, "know enough to be dangerous".
So is there also a video out there where someone runs an extension cord from their neighbors house to get 3 phase electric motor to run?
GREAT IDEA! I'll go talk to the neighbor and see what he says.No ****. As soon as he plugs in one cord the other one is energized.I was told those are called suicide cords!
Same when I had my floors done so appears to be standard practice. Alligator clips are easier/faster/cheaper than calling an electrician to install a receptacle that won't be used again.My daughter hired a guy to re-finish her hardwood floors. The floor sanders was 240V. I did not do a close inspection, but he used some kind of alligator clips to get two hots directly from exiting breakers in the load center !
