DTE
I looked at a Onan generator from a motor home, supposed to run , electric start. I do not know the output. Was wondering if they have a following and any value.
Post the model number, that will help determine if it's worth any thing.
Go to smokstak.com and visit the Onan Generators subsection. http://www.smokstak.com/forum/forumdisplay.php?f=1
More info there than you can shake a stick at.
Yes, they certainly have value, but if mainly suited as a backup unit (vs new enough an RV'r would be interested) it won't be more than $400 or so (around here, based on craigslist ads.) Note that some of the older units actually use the gen end to crank the motor--there may not be a separate starter--these require a GOOD battery but on the plus side, they can crank for a LOOOOONG time without overheating it.
I don't know if they are a direct drop-in to Deere garden tractors (think 318 et al). May have a tapered crank vs ??? in tractor, but likely some (most?) parts would cross over. 1800 rpm vs 3600 rpm way quieter, longer lived, heavier for same power output.
Regards
Jacob
It has no value. I feel the need to help you out so I will take it off your hands providing you pay for the shipping...
Tommy
That's the best offer I have had this morning !
