It's been a little while since I've done circuit breaker work so I picked up a home wiring book yesterday. After comparing pictures/notes I came to the conclusion I didn't understand what I was seeing from my own subpanel
. I have both ground and neutral wires going into one bus bar- what gives? What can you tell me about this picture?
Digressing, I'm in a "new" place. The main breaker panel is strange enough, but in any case, it has two 30A feeder breakers that go 150' down to the shop. The subpanel has a double "sub" main breaker. All this is a bummer because I was hoping to add 240V at 50A for a welder before I finish the walls. Perhaps the Hobart Handler 187 or something equivalent. 30 amps appears to be borderline but unless I have separate power strung up or dig a new line, that's what I have to work with. - - Thanks for your comments.
. I have both ground and neutral wires going into one bus bar- what gives? What can you tell me about this picture?Digressing, I'm in a "new" place. The main breaker panel is strange enough, but in any case, it has two 30A feeder breakers that go 150' down to the shop. The subpanel has a double "sub" main breaker. All this is a bummer because I was hoping to add 240V at 50A for a welder before I finish the walls. Perhaps the Hobart Handler 187 or something equivalent. 30 amps appears to be borderline but unless I have separate power strung up or dig a new line, that's what I have to work with. - - Thanks for your comments.
, but don't want to actually over extend the max. amps (40)
- lol.
, duty cycle in mind.
