One car garage how wide?
drg5490
I'm adding a one car garage onto the end of a pole barn. This addition will have a 2 post lift and the area used primarily for vehicle repair/ servicing...how wide would be a comfortable width 20 ft? Or more? Don't want a monster size so I can heat and cool it economical
gregtwojeeps
Ky
All about what you can afford and will be pleased with. 20 ft is so close to a two car width may as well make it 24' wide and call it a two car. For me, 14' wide for a one garage is nice, as my present one car is only about 12 ft wide and is tight. good luck jmo
Jlbc212
Northeast MA
Check out the outer distance between the posts on the two post lift you would like to get. Add at least another 4ft (2ft each side) just to comfortably walk around. Add extra width for any workbench, tool box you want to place in the garage.
Adk Mike
upstate NY
My shop is 20 wide. Over head door to the far left and bench and work area on the right. Easy to heat. No room for clutter but that was the idea.
D
drg5490
It seems most of the 2 post lifts are about 11-12 ft wide so that would leave about 4 ft on each side on a 20 ft wide garage...I don't know if that's tight or not
rburke65
Canfield, Ohio
My 2 posts are 12' apart, so even with 6' on either side it gives you a 24' width. I wouldn't be going any smaller.
Corsair4360
Logan, Utah
My experience with a 18' wide garage and a two post lift is not good. Walking around the shop to get from one end to another is a PITA.
My suggestion is to carefully think out what you are going to do with the lift. Most of the time we needed the toolbox (a big maintenance unit) at one end or the other, and it is a real mess if the car is high enough you cannot walk around the lift, but not high enough to walk under it. If you are tall (I'm 6'3") walking under is a real pain carrying anything.
I would say that a minimum on either side is 4 feet, and would prefer 6 feet. Of course I am not paying for it....
D
drg5490
Good points things I haven't considered...it's things like pulling axel shafts and stuff like that ...from what I'm reading sounds like 24 ft is what I might need
James-W
Southeastern Wisconsin
It might be a good idea to take into consideration how many tools and how large the tools are that you will be using. The point is, you need room for all that stuff too.
bgarrett
I've heard that you need a space for the car, another space for the interior and another for the mechanicals, maybe another for the tools. Your one car garage is now 50 feet long :)
D
drg5490
That's the way it's looking, my present pole barn is 24x40 and of course too small, that's the reason for adding the 1car mechanical area...
sberry
Brethren, Michigan
You should post in the other thread about the guy wanting to know about a 24 which is really a 1 car garage if you are going to work on it.
larry_g
oregon
This may some what depend on whether your working with compact cars or quad cab 1 ton pickups or larger. Are we to assume this add on is 24 feet long or 40' long? 20x24 would be tight to me, 20x40 would be great. Pay attention to you existing building, does it have 3' wide metal on it? If so then 24' would be a natural size with no waste. What is your pole pitch? Here we use 12', so again 24' is natural. Just a few item to think of.
Also think honestly, are you a neat freak or a mess maker/collector. If you keep your work area neat, lean, and clean then you can make do in a smaller area. If your one to pile things in and 'get to it tomorrow' kinda guy (like me) then your going to fill any area, no matter how big it is. Show us a couple of pictures of what the inside of your current building looks today, and we can decide if your a neat or random kind of a guy.
Good luck on your adventure.
lg
no neat sig line
BearsFan315
Portsmouth, VA
Mine is 20' and would NOT go any smaller....
My plan for me is to go 20' x 32' because i can NOT go wider on my lot... If so I would go 24' x 32' !! for ROOM !!
D
drg5490
Lot of questions great
1 the addition will be about 36 ft long and however wide
It will be set at a 90 degrees angle to the existing building (picture the letter L). So my present bldg is 24 ft wide by 40 ft deep. The new part will be placed at the non garage side of the existing bldg
2. I would like to put a garage door centered in the new addition so I can drive straight in and be in the center of the lift...so if it was 24 ft wide and I placed a 10 ft wide door in the middle, that would give me about 6 ft on either side of the lift columns once inside.
3 . Cars used vary fron compact to 3/4 gass crew cab shortbed.
D
drg5490
Here's what I'm kinda looking at
rusty1
No. Illinois
...no use goin 20',...mite as well make it so 2 cars will fit down the line, if you can offset the lift, you can get 2 cars in there when you don't need the work room....
