One more garage door question
yorginomics
Hi guys.thanks for the previous input ,this leads me to next question.
My door is just under 12 wide and 8 high....my garage is 20 wide od...I used prefab trusses for speed and simplicity.
So they are not designed to hang weight of of them ...so what would best solution be to hang horizontal ceiling tracks....???
Rusted Nut
Northern Arizona
You must have provided drawings to the truss manufacturer, so I would think they would have designed the trusses to accommodate door tracks, if a door was shown on the drawings. Call the truss company to verify. If not, you’ll have to add some sort of structural members to attach the tracks to.
Y
yorginomics
Standard truss from building supply place...they also did drawing.....i don't want to hang off of them.if possible
firebirdparts
Kingsport, TN
Garage door weight is trivial. It's strange, I guess, but this question has never come up here. If somebody had asked me, I don't suppose anybody ever built a truss building and didn't hang the tracks from them.
CraigStu
Blacksburg, Va
Are you trusses standard 2x4 construction and on standard 2ft centers? If so, join the other 10 million garages and hang the door from them. Don't forget that the end of the tracks near the wall are supported by the vertical track portion that is sitting on the concrete floor. So your trusses are only supporting 1/2 of the door's weight.
TurnipTruck
Southcentral Alaska
I have never seen a truss that couldn’t handle 10lbs/ft2 dead load on the bottom chord. Most truss sheets even state that unless built heavier.
Imagine doing pull-ups from your truss. Two or three people will outweigh your door and the truss will handle that, especially at only a 20’ span.
