I bought this little portable system for when I cannot get the workpiece to the plasma cutter or the plasma cutter to the workpiece. It uses the 10CF MC acetylene cylinder, 20 CF type "R" oxygen cylinder. It is for "emergencies" or as a headache preventive. It will not be a daily used item.
It came with valves and check valves, but no flashback arrestors and/or non-return valves. From what I gather, a check valve will not stop a pressure or shock wave. Should I install the flashback arrestor or non-return valves? And, at the valve end or the torch end....or both?
I don't mind extra safety. I just wouild rather not go short and risk an explosion. I do have several friends who are very experienced with this, but wanted to see what you think is the safest thing to do.
They can help me with learning to light the torch, setting the flame and cutting and shutting down with hands on one on one demonstration. But, if you have any suggestions, comments or pearls of wisdom with proper technique or procedures, I will be more than attentive.
Thanks
Thanks
