Years ago I worked with a team where we had to test complicated equipment and debug a lot of issues. One saying we had was "One rat - Many rats". The thinking was that a farmer walks into his barn, and the first thing he sees is a rat in the grain. What are the odds that he just saw the only rat in the barn? You're right - the odds that there are more rats is high. We used this perspective in our testing, so when we found an issue in testing we'd add a bunch more tests targeted to that area to try to find more "rats".
So recently we had a leak in a wall of our house, and that led to a lot of work in fixing it. As part of the fix, I opened up an outlet in our finished basement, and I found that the grounds looked like the picture below. Hmm. So I opened up the other five outlets in the room and four of them had the same issue.
Besides the bad grounds (the NEC is ok with three or more twists, right?
) all of the outlets were back-stabbed, and about half were loose to the wall. Also about half of the outlets used crimped ferrules for the ground connection (which I think met at least the older NEC reqts) but most of them were loose due to being crimped by pliers and all are replaced.
Needless to say, I am on a jihad and methodically going through all of the outlets in our basement. Trying to make lemonade from lemons, I am also making a breaker/light/outlet map at the same time. Once I get done with downstairs I'll hit upstairs, and after that I'll check all of the switches. Lots of work, but I figure it's better than burning down my house or getting electrocuted...
And remember - one rat, many rats.
