Hey everyone, I replaced a light fixture on a small/finished out-building's porch light that never worked since we bought our property. I assumed the fixture was bad, and we wanted a nicer-looking fixture anyway, but after replacing the light fixture and putting a new bulb in it, the new fixture did not work either. I tried another bulb, then started checking the voltage, first at the fixture, which was showing only about 65 volts. I went ahead and swapped out the switch, since I figured that would be a potential quick & easy fix, but that didn't fix it, and I am showing the same 65V at the switch as well. When I put my multimeter probes on the hot and ground wire of the switch (instead of on the hot and neutral), I get 120V.
I opened up the electrical panel to see if there was anything fishy there. The only thing I found was that there were two neutral wires that were connected to the ground bar, so I switched those over to the neutral bar. I didn't necessarily think that would fix anything (which it didn't), but I figured I might as well correct that to make the connections proper. There was also a double-tapped neutral that I corrected as well.
Anyway, since I'm not seeing anything in the panel or in the switch box that looks incorrect, what else should I look for to correct this type of voltage issue?
Thanks in advance for your input!
