bowhuntr311
Hey all,
I came here hoping for some advice to see what route I should pursue for heating my detached 40x40x10 detached shop.
Outdoor woodboiler is going to be my source of heat and I currently have floor loops of pex for heating the floor that I want to hook up to a pressurized closed system. I was hoping to use my floor heat as a constant heat at say 45 degrees and some kind of coil/fan system for an on-demand air heater.
{Im coming home from work @ 5:30 and decide I want to work in my shop that evening. Floor heat could take several hours to warm it up to 60 and i would be done with my project by then; Im hoping the coil could be 20 min and be up around 60}
Im was hoping to run the open side above the floor heat system to a hanging coil and the return side back down and out to stove. The coil would be ABOVE the stove in elevation by a few feet with out a doubt. Several people said it'll never work and the pump wont be able to push the water up above the stove and it'll vapor lock and through the coil and back to the stove and several had said it'll work with a good pump and an air trap release (air bleeder) but cant offer any specs to a pump I would need?
One person suggested running another loop off the floor manifold through the coil. My closed system water temp at 110 doesnt seem like it be very hot air coming off the coil?
Any advice out there?
