I retrofitted our living space to open structure and got rid of the ceiling gypsum board. Some supplemental steel was added because I removed every other truss to open up the ceiling appearance more. I added a few X bracing to transfer the lateral loads on the double hinge wall to the portion that remained with the ceiling. Everything got painted white.
On the roof I added 1 layer of XPS (taped seams) and 2 layers of 3" polyiso rigid insulation. All joints staggered, then new 2x6 flat wise screwed with long SIPS screws into the trusses, then 23/32" plywood to span the 48" module. This type of construction is called nail base. It's basically a site built SIPS. The roof was getting replaced anyway. This portion has a step on the roof, but if I don't tell folks, they don't know. It's been like 6 years, and has worked very well. But it was pretty spendy.
We are used to it, but folks kinda get blown away the first time they come.
