Hello,
I opened up a switch box ion my garage today and became a bit confused. I took meticulous notes. However, I do not understand what is happening in terms of the circuits when I opened up the box. Everything works fine and tests out with a electrical circuit tester. I am just sort of puzzled.
Here is what is inside the box.
1 three way switch which controls the lights inside the garage.
1 switch to turn on the service light outside the access door.
1 outlet.
I have 3 pieces of 14/2 Romex coming into the box.
I have one 14/3 piece coming into the box
1 have a red conductor and I can plainly see that they are using it as the traveler wire.
1 wire obviously feeds the service door light switch.
As for the other two 14/2 wires coming in….I assume they are going out to feed other things. Ceiling outlets etc.
I am guessing if I turn on the juice and meter all the wires I would hope I have only one hot one coming in. I assume this because the breaker kills all juice into the area. I tested that before working on it.
I assume the three way one would be hot and they jumpered/fed the two way switch for the service door light off that hot? Or would they bring two hot in from the same breaker?
Anyone have a good test procedure I could use to determine this? As you can tell this circuit makes me dizzy. I was surprised to find more that two wires in there.
Also perhaps a good book on home wiring that you could recommend?
If you need a detailed wiring diagram I guess I could draw one up.
TP
1 outlet.
TP
