Opening up a tire shop
mrpizza
IL
You should probably get several. Hf earthquake or an ir 231c
94yj
fort worth texas
it depends a lot on what you are going to be working on cars and lt trucks i would go with an ir 231 any thing bigger is going to need at least a 3/4" impact or a 1"impact
Strouty
Southern Maine
lets hear yours
I like my older blue point, I don't even know the model number. I changed the bearings in it and it works very well. I also have a 3/4" drive HF earthquake that is loud, but works well so far.
What type of tires will you be doing?
KEH
If you are going to change big truck tires, you need a 1 inch drive air wrench.
KEH
kwb
PNW
If you are opening a tire shop and don't know the tools I really hope you have some outside council in general for operating a business.
stikman56
I like my cornwell 1/2" 1200 breakaway torque only paid $260
The Cornwell CAT4150...great wrench. This is also the Napa 6-1123. Strong, light , ( just under 4 lbs.) and the shortest 1/2" (full sized ) composite I can think of. One of my favorites for sure. I would make sure whatever you get exhausts out the bottom of the handle, the IR 231c does not, it's out the front. IR 231H,and 231HA exhaust out the handle and can be had with extended anvils as well.
shampoop
SW Washington
Get a IR 231-2 with the extended nose, better for clearance especially on 4wd.
+1 flip sockets can be easily used also.
Most important thing about shop owned air impacts at a tire shop is that they can take abuse. And those things have been proven to take any and all kinds of abuse for years, powerful and cheap to buy too. Shop owned tools will be abused and not maintained.
