viyer06
Hi - I just had a multi zone ductless mini split installed (Carrier brand). 12k BTU in the upstairs master bedroom, and 12k BTU in the dining room on the main floor. We have a 24k condenser outside that has heating and cooling.
I've been playing with this system the first day and I'm new to ductless and trying to figure out if something is wrong with my install.
Here's the issue:
Upstairs theromostat = 68
Mini split set to 64 on the heat only setting.
Downstairs thermostat = 70
Mini split set to 75 on the heat only setting.
The downstairs unit pumps heat in order to get the thermostat to go from 70 to 75. This makes perfect sense.
Now, when I turned on the upstairs unit, the upstairs unit should not be doing anything because the room temp (68) is already higher than the mini split temp (64). However, the upstairs keeps blowing warm air. I'm thinking its because the downstairs is blowing heat to raise the temperature.
Ideally I would expect the downstairs to blow heat and the upstairs to do nothing. When I use only one mini split at a time, it works perfectly, this issue seems to only arise when both units are on at different temperatures. Since this is multi zone, I figured it should be able to operate totally independent of each other. Is this how a mini split is supposed to operate? I checked the wires. and it doesn't seem like anything is crossed at the condenser.
Here's the issue:
