KissMyWhiteSS
Ok so I have had a few questions on here in the past dealing with electrical work. One post was a rather dumb post mostly because of my lack of experience and knowledge, but mostly because I wasn’t using common sense. I was quickly told to call an electrician or somebody who has more experience, to help me. That is fair. Up until I have been able to handle everything on my own, ie: running wire, connecting outlets, and preparing my sub panel. But now I am at a stopping point where I will be calling an electrician to come out and “finish” it. Before I do that though, I want to make sure that I am educated enough to know what the guy is doing, and WHY he is doing it. So I am going to do my best here to explain my plan and what I have done, or what has been done to my detached 20x24 garage.
First, the garage is a detached 2 car in a Charleston style neighborhood. What that means pretty much is that the house faces a street and the garage is about 15 feet behind house and faces an alley.
Goals:
I want a clean, simple place to store/work on things such as cars, wood work etc. I do not have any crazy tools, just mostly circular/chop saws, a drill press, and a shop vac. I also have a fridge for the brewskies and do plan on having a wall for a tv and stereo set up.
The garage has a 20amp 110V 12/3 feed wire coming in from the panel inside my home which runs directly into a 4 gang light switch box. 1 switch controls the light on the outside main door, 1 switch controls the light on the outside of my service door, 1 switch controls the 2 – 4’ fluorescent light fixtures and the other switch controls my attic light up above.
Now, there is also a 12/2 wire coming into the garage in the same conduit that is wired into a 3-way switch at the back door to my house. This feeds a switch that reads “Main Disconnect” that then feeds the only gfci that THEN runs into my 4 gang box. I have not pulled the cover off the box to look inside yet so I do not know how that is wired.
How can that single switch cut off the power to the 4 gang box switches? Would that make it a 4-way switch? I am trying to fully understand this.
I hope you can picture everything I am explaining.
I purchased a 125 amp 6 space circuit panel with the intentions of using at least 5 for now.
1 circuit will control the light switches
1 circuit will be dedicated to my fridge
1 circuit will be dedicated to the right side of the garage
1 circuit will be dedicated to the left side of the garage
1 circuit will be dedicated to the tv wall.
Everything is wired and ready, except for wiring the feed wire into the sub panel.
My father in law, who has enough experience that I trust his word, told me that I should run 220 out to the garage. So I bought a 30amp 2 pole circuit breaker to replace the single pole 110 amp breaker. My issue that I see now is that where the single pole garage breaker is in my panel, there is no room near it for a 2-pole. So I have to have the breaker for the garage moved to a lower location in the panel, which will result in my wires being too short. How many of you have used wire nuts in your panel to splice in your wires? I know it is ok by code, it just seems like something could go wrong? My other option is to shift all the following breakers down in the panel. I could get away with not having to use wire nuts then….but I’d have to re label every location on the door. What would you do?
Lastly, after the feed wire is connected to the sub panel in the garage, what wire should be ran to the light switch from the new circuit? 12/2 or 12/3 and why?
I know this is a lot, and I promise I have done more research on this stuff than I have running the wires in the garage. Some things just haven’t been very clear. School me if you can, but dumb it down. I’m not an electrician. Thanks in advance.
Goals:
