Opinions needed on new Craftsman Floor Jack.
kidder
PA
I currently have a 10-15 year old Craftsman 3 ton steel floor jack. I recently got a new car and my current jack really does not fit under the car readily. Not only that - but I have always hated the way this type of jack would release the pressure (on or off, hard to modulate). Does anyone have one of these jacks or at least seen one in person? My local Sears Hardware retail stores do not stock it. Thank you in advance!
Craftsman Professional 3 ton Aluminum Floor Jack
Sears item# 00950244000 Mfr. model# 50244
http://www.sears.com/shc/s/p_10153_12605_00950244000P
nissan_crawler
Wichita, KS
Lightning
I recently bought a cheap 3 ton floor jack for about $80.00 I decided not to spend much on this item because I only plan to use it once every two to three years.
tanda4
IL
I went through 3 Craftsman jacks in 3 years. And I am just a casual jack user, maybe 1 time a month. The 3rd was the SUV jack and the (common problem) seal blew out. I will not be buying another craftsman. When funds allow, I will be buying a quality jack. The 3 Craftsman could have paid for a quality jack that would last much longer.
The problems I have is one, my car is very low and two a large size saddle will not fit due to the rocker panels.
Lightning
That is terribe. Can you replace the seal and fix it?
Lightning
My jack is probably a low quality ****, but I do not plan to use it much.
MAD
Western MA
Spend about $100 more and get a Hein Warner HW93652: http://www.jackxchange.com/products/HW93652.cfm
The funny thing is that the same company that supplies the horrible jacks to Sears owns Hein Warner.
http://www.shinnfuamerica.com/(S(4ocdmojivazmfb45kaaqpuj0))/AboutUs/AboutShinnFu/Default.aspx
These crappy jacks illustrate the damage Sears is inflicting on itself for short term gain. You would think after several years of 1 star reviews someone might notice there is a problem with these. There is money to be made selling these but by branding them Craftsman they do themselves a great disservice in the long run.
Underdog
Treasure Coast, Florida
I researched this thread since I needed a new floor jack. My old china pos stopped lifting and so in the scrap bin it went. I wanted a American made jack and this one seemed to fit the bill.http://www.tooldiscounter.com/ItemDisplay.cfm?lookup=HEIHW93652
Well ups dropped it off this morning and in a few minutes I had it unwrapped and found the rear casters would hardly swivel. Upon closer inspection one side wouldn't move the other somewhat. As I played with the casters by hand about ten small roller bearings fell out:mad:I went for a wrench to remove the top nut on the caster and 1 1/16" too small, 1 1/8 too big? Metric nut?
The casters I think are china made even though in big letters on top of the jack says Made in the USA. Have to get on the phone tomorrow and see if they'll send two new casters out. Oh well I tried.
eschoendorff
Ouch, that ***** man. Especially for the $$$4 you paid for it! :(
billymade
New Mexico
Did they make it right for you? If they didn't contact the manufacturer!
Hein Warner Customer service is:
Shinn Fu Company of America, Inc.
10939 N. Pomona Avenue
Kansas City, Missouri 64153
United States
Telephone: (816) 891-6390
Fax: (816) 891-6599
Email: [email protected]
By the way; what did they charge for shipping for the jack? I noticed it was 110 lbs. but when I tried to check out on the website; they didn't show a shipping charge for the first shipping type, UPS Ground Saver. Is their shipping free? :confused:
nissan_crawler
Wichita, KS
HF 2.5 ton long frame, lifts 32" vs the Hein-Werner 23", worked perfectly out of the box, $140 vs. $330, larger wheels.
eschoendorff
I too have had great luck with HF jacks. Go figure...
I'm all for buying American, but for the extra expense, there should be better quality!
Chief
New Jersey
Great Web site
First post.
I could not agree more. I went through 2 2 1/4 trolley jacks in less than a year. They were constanly leaking fluid and bleeding out.
Finally I bought a 3 ton floor jack at HF for less than $60. I will never buy another craftsman jack. I would go the HF route and treat it as disposable or buck to buy a good one.
jay50
I have a Torin Big Red 3T floor jack; works great. Not sure if it is made in same slave factory in China as the HF model but it gets the job done.
Mugenlude
SE WI
I do a lot of car racing on the weekends, so the jack needs to be low and easy to get around, so I decided to purchase an aluminum jack because of the weight vs. a good 'garage' floor jack. I went through a couple HF 3,000# (which kept blowing out seals) jacks before I purchased this Craftsman aluminum jack.
http://www.sears.com/shc/s/p_10153_12605_00950239000P
I have been using for 2.5 years now (in the garage or at the track an average of 2 times a week for the year) and it hasn't had any problems. I'm only lifting a 2,000 lb & 3,000 lbs cars though, I haven't tried it on anything heavier because I didn't have anything heavier.
I'm not saying it the greatest jack, I know that, but for it's purpose it has served me well. However, now I do need to purchase a new jack that can get my Excursion in the air, so I will be purchasing something more heavy duty which will just stay in the garage.
To the original poster, do you plan to be transporting the jack around? If not, I don't see the need for an aluminum jack.
cb450r
Looks like a good quality jack for the $$
I am looking for a jack as well and am not impressed with the aluminum stuff.
PAToyota
South Central Pennsylvania, USA
I've been fairly pleased with my HF 3-ton jack - except for the modulation issue that you mention. I have a feeling that is just the nature of the beast for this type of jack - unless someone else has other experiences. In which case I'd really be interested in hearing about the options.
Recently I've had the need for a second jack around the shop and am trying to decide between one of the "lighter" aluminum ones (sorry, but 70 lbs. is still pretty freaking heavy) and one of the long frame ones (which, admittedly, is even heavier).
[edit]Sorry, for some reason I thought I saw a weight of 70 lbs. on the one I was looking at, but now I can only find a 2-ton aluminum model weighing 45 lbs. I could have sworn that they had a 3-ton aluminum model...
Underdog
United States
Fax: (816) 891-6599
They charged $80.00 shipping to Florida. Talked with the distributer today and they said they would have the manufacturer ship me two new replacement casters today or Monday. Thanks for the links.
eschoendorff
This thing is definitetly not Aluminum. I think it's about 100 lbs or so!!!
I don't see what the big deal is about having an aluminum jack anyway - unless you race on the weekends (like Mugenlude) and need portability. Give me steel/cast iron anyday...
Danglerb
SoCal
Its a simple choice, do you need to pick up the jack to move it?
YES) Aluminum is going to be a LOT less work.
NO) Heavy steel is stronger and cheaper.
TxDoc
I have the same jack that eschoendorff shows. Use it about twice a month and have had it for about 2 years, no problems. I had the orange and white one, first and it could not hold pressure. Took it back and HF traded it out for the black and yellow one shown. A 15 or 20% coupon may help, too.
Good luck on your search. Maybe get some jack stands, too, if you don't already have them. I always use them, no matter what, just in case the jack does fail.
