gpstraub
My Ridgid oiless air compressor has been acting funky for the last few days. Over the weekend, it runs almost constatly to keep a full tank for for simple tasks like quick 5 second bursts running 60 psi for blowing out dirt while cleaning guns, filling tires, etc. The pressure relief valve and water drain valve are both sealing well. I'm guessing it's a piston or diaphram. I'm sure it's fixable but I'm considering an alternate route.
One of my customers owns a dental practice that uses compressors for all the the drills. They recently replaced the compressor after adding multiple exam rooms. They were confident the old compressor was up to the task for the expansion but upgraded the compressor for peace of mind.
The old compressor was working perfectly and I have seen the records that the unit has been serviced by a local reputable company every six months for the last 8 years. I called the service company and they are unaware of the tank size or cfm numbers because they didn't install the unit.
It is a 1982 Kargard Industries oiled unit twin cylinder. The model is an A63638. I couldn't find any specs on the unit online but I think it might be a good fit for me. It has a a 230V 1 1/2 hp General Electric motor rated at 10.4 amp phase 1 motor.
I'm completely confident that it's in great working order and the doctor said he'd be willing to give it to me for almost free.
My only worry is.... if I go to all the trouble to move it and install it, is it a worthy upgrade? I have no idea what the capacity of the tank is or how much air it will move. My current Ridgid is a OF45150 with a 1.8hp model with a 4.5 gallon tank running 6.2 cfm at 90 psi. There is no spec on the tank size of the Kargard model but I think it might be 8 to 10 gallons by "eyeballing" it but I'm a terrible guess at that sort of thing.
I don't use the compressor for much other than running low load tools from time to time but I like the idea of being able to run a 3/8" or 1/2" impact gun from time to time for removing rims, etc.
Sorry for being long winded but I like to supply sufficient background information for anyone nice enough to provide any suggestions.
Thanks in advance for any help!!!
