In the Atlanta area, and Georgia and the south in general, you don't find the "Craiglist deals" everyone seems to find elsewhere. Not sure why, but old machinery just doesn't seem to be available.
I have a Grainger/Dayton Drill press. It was damaged, appears to have either been struck or fell on the face of the head. Shattered the switch and cracked the head top to bottom. Turns out, the section cracked is a thin false front cast on it mostly to mount the switch. The rest of the head was not damaged and I had priced a head before I bought it, but after setting it up, and drilling with it, I concluded it drilled straight and did not bother replacing the head. I installed a Square D Forward/Reverse drum switch on the side of the head (motor was reversible but was not wired for it, I added that in a flex conduit with the switch), and bought a Jacobs 3/4 chuck on a MT3 arbor off of Ebay and installed it. It had lots of wobble and I could not separate the chuck and arbor and finally took it to work where our company machinist, with the help of some liquid nitrogen were able to separate the chuck (a Jacobs 18N ball bearing model) and reseat it on the arbor. It now drills very straight in the drill press, about a half of a thousandth runout at the tip of a typical drill bit. Grainger's list price was over $1600 at the time and I paid $600 for it.
Charles
Floor Drill Press, Swing 20 In, Motor HP 1, Voltage 120, Hz 60, Amps 16.0, Capacity Cast Iron 1 In, RPM 150, 260, 300, 440, 490, 540, 1150, 1550, 2200, Spindle Travel 5 In, Spindle to Table 25 1/2 In, Max Spindle To Base 47 In, Column Dia 4 In, Table Work Surface 18 5/8 X 16 5/8 In, Tilt Angle Left or Right 45 Degrees, Overall Height 68 In, Overall Width 19 In, Overall Depth 34 In, Chuck Size 5/8 In, Includes Motor, Drill Chuck with Key, 6 Ft Power Cord
