opinions on this compressor
MacMcMacmac
canada
Probably not a bad machine but "2 stage performance from a single stage compressor" raises some concerns for me. That's not the first time I've seen HD running single stage compressors at way too high of a cutout pressure. If i bought this machine I'd set cutout around 120-130psi and not cook it to death making more heat than air. I think that's why they put that flywheel on it with all the fan blades. 175psi is a recipe for a short life for a single stage compressor. Long enough to get it out of warranty I suppose. Win-win for HD.
Nice looking dog. Had to put my Malamute down on the 11th. Special dogs. a bit stubborn but you can't help but love a dog that sings with you.
Citation
Indy
It looks like the same pump used on this DeWalt branded 60 gallon (for $~80 less)
https://www.tractorsupply.com/tsc/product/dewalt-60-gallon-air-compressor-155-psi-dxcm601-1313326
They can probably get away with the high pressure because the aluminum head likely cools better than a cast iron head. It probably is not very efficient at that high pressure but can do it.
Personally, unless you really need the portability or cannot do a 60 gallon, 240V, stationary compressor I would consider something else. I mean I consider a belt drive, oil lubed pump compressor like that one to be about as good as any 120V compressor gets. The problem is they cost just as much as a 60 gallon, 240V compressor that will deliver 2x the air flow. As good as that compressor is, a 4" cutoff wheel, used extensively will still outrun the pump and tank. I had a 20 gallon, 130psi. 5.7 cfm compressor. I got less than 10 seconds of good work out of my cutoff wheel before I needed to let the pump catch up. Using the same tool on my brother's 80 gallon, 145 psi, 10cfm compressor I never ran out of air thanks to the normal pauses in cutting. The step up in capabilities when you go for a 240V compressor is huge. You may not need that extra ability but in that case I would generally suggest spending less. I wouldn't have paid the full $400-500 retail price for my 20gallon compressor.
So overall I don't see any obvious issues with that one but I would consider either spending less or going 240V for the same money.
94yj
fort worth texas
thanks i was beginning to think the same thing as a 2 stage would be better what is your opinion on this compressor?
https://www.lowes.com/pd/Kobalt-60-Gallon-Two-Stage-Electric-Vertical-Air-Compressor/1000542193
Citation
Indy
Seems decent enough (the 6.9cfm rating is a mistake, reviewer pictures show somewhere around 12cfm)
I think it's another CH OEMed compressor. On paper I don't see much advantage over the cheaper one from Tractor Supply.
Crabman
Alexandria, VA/Dameron, MD
TSC also has the Dewalt 30 gallon for $125 less than the Husky if space is a problem.
https://www.tractorsupply.com/tsc/p...n-air-compressor-155-psi-dxcm301?cm_vc=-10015
I needed a smaller one also and got the 24 gallon Porter Cable from TSC for $159 (sale just before Thanksgiving), and so far it has been great.
I would be tempted by the Dewalt 60, which seems a great deal for DIY like me, but I have a blast cabinet that eats air.
Good luck finding the right fit.
Bruce
Rinspeed
NY
I bought that 60 gallon Dewalt last year on Black Friday from TS and have been quite happy with it. The reviews are pretty good at the price point. I believe Sanborn is the manufacturer and they are asking $800 for what looks like the same unit. For $413 that is a hell of a deal in my mind.
u2slow
BC
I like the 240v/3hp portable class machine. 10cfm. CH and Speediaire have offerings. Decent price point to get twice the air of most 120v machines.
vanapplebomb
Holland, MI
Yes, Sanborn mfg currently supplies Dewalt’s 30 gallon through 120 gallon compressors. It looks like they may make a couple small 15 and 20 gallon units as well. Sanborn mfg is one of the major forces in the compressor industry that most people don’t even realize is there. They make a good chunk of the 30 - 120 gallon range compressors on the market today. Industrial Air Machine is their own brand, but they make those same compressors for just about every retailers house brand, save for Lowe’s which cheaped out and switched to less expensive Campbell Hausfeld units a few years back. Lots of tool companies come to mind as well. Eastwood and MAC Tools are just a couple others that source from Sanborn.
For the record, I am not a big fan of CH consumer and light industrial grade pumps. They are not built as well as other pumps on the market in the same price bracket, and are generally not as efficient either. Not saying they are a bad pump, just that there are other compressors I would chose over a CH. that’s all.
dalepres
Park Hill, OK
Consider that more important than how often you are going to use your compressor is what you're going to use it for when you use it. Even the one the OP mentioned in post #1 could be overkill if you're only using a finish nailer or stapler or inflating tires. But it's too small if you're going to do HVLP painting.
Spending $500 on a compressor when you only needed a $200 dollar compressor may not be a bad thing if you find out you need the extra capacity but, if money is important, it could also be a waste. That said, spending $500 could be a bigger waste if you end up having to buy an additional one for certain uses. That's why my suggestion is to buy as big as your budget and space allows or buy as little as your current plans require. It's that middle ground, the luke-warm water ground, that might be the most wasteful - at least for me; your mileage may vary.
94yj
fort worth texas
i am thinking about this one and wanted to ask how you like it and any problems with it so far also how noisy is it as i have a small 2 car garage it will be going in please let me know thanks
Rinspeed
NY
I've been very happy with it so far. When I bought it I didn't have the $800-900 it would have cost to step it up to the next level. I looked at used as well but couldn't find a deal close to me. Not a single issue with the Dewalt and it keeps up just fine running a die grinder. It replaced a Craftsman 30 gal oilless which was very loud, in comparison the Dewalt is much quieter. I'm slightly paranoid about my hearing and have muffs on most of the time I'm running equipment but the Dewalt is not loud enough for me to consider ear protection when it kicks on. That sale might have ended yesterday so I would call this morning if you're interested, I don't think you will be disappointed.
