Optima Charger?
tegguy
Anyone here run the Optima Digital 400 or Digital 1200? I have a red top in the chevelle and a couple times it'd gotten deeply discharged and it was a pain to bring it back. I'm thinking about buying the 1200 but I wanted to see what other people thought.
mobiledynamics
Gotham City
Ctek chargers all the way. The marketing on the Nocos are better....but personally, I think Ctek is a better rounded product..
T
tegguy
Do the Ctek units offer all the features of the Optima as far as ability to charge a deeply discharged battery without needing a second one and the over charge protection?
mobiledynamics
Gotham City
I don't treat ~smart~ battery chargers as set and forget.
For deep discharged batteries, where you need to outsmart the brain, you can either hook up a additional battery OR put the charger on supply mode, check voltage on battery and once it get's up to X volts, then switch it back to smart charge *automatic* mode.
I like Cteks
Noco would be a 2nd choice, but the Cteks just seem a bit better in overall build
T
tegguy
That's the good thing about the optima is it'll automatically adjust for the deeply discharged condition. I'm trying to get away from having to hook up a second battery when mine gets too low. Eventually I'll get a batter tender on it but that'll be when I get it running right.
mobiledynamics
Gotham City
If you have a AGM style battery......high voltages will kill it.
AFAIK, u need a high AMP charger for a AGM battery ...hence the reason I have the 25 amp Noco in my stash....
Cteks and Noco are great in long term investments as a charging system. Pigtails/leads you just install and hook up to the chargers, etc.
Optima is all marketing IMO...
SkinnyG
Orange Park, FL
I have both the 1200 and the 400. The 1200 is a fantastic charger, especially when dealing with a deeply discharged battery. I'm not sure if the 400 can manage a full size auto battery that's deeply discharged. Honestly, I've never even used my 400. I've never had a need for it, as the 1200 will automatically switch to a maintain cycle once the battery is fully charged. One day I'll get around to mounting the 400 somewhere in the garage where I can keep it as a permanent maintainer for the car.
They work great for standard batteries as well, not just Optima gel-cells.
