AmericanPreferred
- Joined
- May 8, 2013
- Messages
- 159
I know the rotator's didn't catch on so good, but mine have saved enough work for me to keep em around. I have the Blackhawk version in 1/4 and 3/8. My only complaint is the heads are pretty dang thick esp the 3/8. Has anyone seen an adapter from 1/4 to 3/8 that does not add thickness to the ratchet. The 1/4 hole would be inside the 3/8 square. It would also be nice if this piece was magnetic to help hold the fastener, as well as the socket since the spring ball would be lost. I can make my sockets shallow enough, but if a set is out there I would like to have a look. BTW I have GearWrenchs, and pass thru kits all ready, but being able to get on a bolt does not mean you can turn it with either of these. Generally speaking if I can get the rotator on it, I can quickly remove it if I can break it loose. Being able to hold the bolt for starting would be ideal in many situations as well.
