Options for meters with inrush?
gamp945
Hello all,
I am in the market for a new clamp meter. I'd like a model with inrush. I am not a pro, and am hoping to not spend a fortune to get a meter with inrush.
Please note that inrush is not the same thing as a "max" setting:
The obvious option is a Fluke 374, but these are about $400.
An alternate option is the Fieldpiece SC440 which costs about $180. I've read very mixed reviews about Fieldpiece though.
Another option is the grey-market (India, China, etc) Fluke 319. These are available on eBay for about $270. This is still more than I'd like to spend, but may be my best option for a good meter with inrush.
Any other options I should be aware of? Thanks for reading.
not many options for in-rush reading capability.
you definitely dont want to cheap out on your meter
I have a fluke 381....
Supernaut
Annapolis, MD
A cheap Mastech MS2108 on amazon ($90) gets good reviews. As far as cheaping out on a meter, I'd instead say don't overpay. If you're a pro, go ahead and spend for pro equipment. Fluke 381 approaches $500...
  • Like
Reactions: Max
Max
Georgia
Welcome to the forum Supernaut!
The problem with cheap meters is that you use a meter to tell you something. And if the meter is wrong, it can send you in the wrong direction when you are debugging something. It’s kinda like a torque wrench - the only thing worse than no torque wrench is a torque wrench that reads wrong. I am not really disagreeing with you - more just noting one reason why people do spend the money on higher quality meters..
rlitman
Long Island
...The problem with cheap meters is that you use a meter to tell you something. And if the meter is wrong, it can send you in the wrong direction when you are debugging something. It’s kinda like a torque wrench - the only thing worse than no torque wrench is a torque wrench that reads wrong. I am not really disagreeing with you - more just noting one reason why people do spend the money on higher quality meters..
Perhaps, but I don't really see it that way. As I see it, any digital meter will do nothing more than provide a number, and it is up to the operator to interpret that result and in particular, its validity. I've been misled by DMMs before, and price wasn't a factor, but at least I have the wherewithal to know when the display is not to be trusted. OTOH, a good old analog Simpson has never steered me wrong, but isn't going to be able to provide an inrush reading, because d'Arsonval movements just have too much inertia for such a use.
I personally would use my Amprobe ACDC-52Nav for this, since I have it, but all AC/DC clamp meters work on the principle of a hall effect sensor and integrating chip, and depending on the OP's needs, most likely any one, including the Mastech will be just fine.
  • Like
Reactions: Max
Supernaut
Annapolis, MD
Thanks! Glad to be here. Long time lurker. I'll post more as my new garage gets built up.
Agree cheap meters can be a problem just like inaccurate torque wrenches. My approach is to pay for what I need, not overpay for something that I don't. I'm not a pro or amateur, somewhere in-between, so can cut some corners and square up others.
Funny you mention torque wrenches. I'm restoring an old car, and even with the most accurate wrench I still don't know what the torque spec should be since the factory manual is useless. But forums like this help me figure it out.
  • Like
Reactions: Max
Max
Georgia
Fair enough. To me, some of the most common reasons to get a better meter like a Fluke is better accuracy, better specs, and a presumption that the inputs are actually as protected as the manufacturer claims. For a clamp on current meter, it's not that likely that you'll care about absolute accuracy, and the input protection is irrelevant as you're not connecting to the voltage/current source.
Specifications may or may not be an issue. To be honest, for inrush current I'd use an oscilloscope. But for a DVM trying to measure inrush current, how fast it samples and how it determines the peak current is important. If you understand the specs and the trade-offs vs. what you are trying to measure there's no issue, but if you just want to clamp and go you may have issues. That's all I was trying to point out.
I have a Simpson 269 myself, but unless I am nulling something it stays in the cabinet. :)
MBfreak
MEMBER EMERITUS
Linkoping , Sweden
And if it is AC current you want to register inrush peak on, use a traditional current transformer and conevert the current value to volts in a low ohm resistor , scope the voltage. They are often designed to measure within a fraction of a % at nominal value and can often measure more than 10 times nominal value within 5 %. And 60 Hz is no problem at all.
Ola
