Mark100
Hello All,
I have three options (that I know of) to run natural gas to my new detached garage. The meter size was increase 5 years ago to allow for a standby NG generator. According to my gas load calculation, there is more than enough capacity with this meter. The regulator is installed at the meter and rated for 6-8 IWC. I will be adding a 45k to 60k BTU unit heater or tube heater to the garage. The line run for both options would be about the same at 150 feet. The gas meter is on the opposite side of the house from the garage.
Option 1: Run 1" direct bury from the meter around the house to the garage. This would be about 150 feet of direct bury poly tube.
Option 2: The inlet into the house is 1" black pipe and runs about 50 feet before it branches off for all of the gas utilities. I could tap into the 1" line before the appliances and run that to the outside of the basement and then use direct bury for 50' to get to the garage. Basement utilities are all accessible at this time, no ceiling.
Option 3: Branch off of the 1" inlet directly inside of the house and then run a parallel 1" through the basement to outside and then direct bury to the garage 50'.
I always get some good info from the board and I am hoping these pictures will help.
