options for workbench surface 30"x10'
infinkc
i have a workbench area that i need to get a top for.
Was thinking possibly trying to find a piece of stainless of get a stainless restaurant table.
i will probably do occasional welding on it, so was thinking just regular steel.
thoughts on thickness? materials? pictures?
thanks!
matt_i
The thicker stuff is nice as its not as affected by concentrated heat.
Stainless looks nice but they you get spatter and have to dress it with a flap wheel and that's probably going to be a sad day.
If you can get HRP&O (hot rolled pickled & oiled) they previously remove the mill scale which makes it just a bit nicer. Looking at my Alro catalog, A36 HRP&O is only available up to 1/2" thick.
Many steel yards have processing via flame cut, shearing, laser or waterjet. Depending on thickness the shear can put a curl into the metal via the stresses imparted during the process. Laser would be my choice if they can do the thickness that you want.
The first steel bench I made was 5/8" thick and I had them ship the "drop" after shearing 8" off a 48*96 to get 40" x 96". I made that drop into several more useful things over the years.
Just also had a thought that you might be able to find a 36x 120" as-is at the steelyard, no processing needed. Alro stocks that size in several thicknesses. Looks like up to 7ga in the 36*120 size, just shy of 3/16" thick.
I
infinkc
called a local steel yard, 3/16 is running about 275 for the 30x120 piece. so leaning in this direction. Should i go 1/4 instead? not sure how much that 1/16 makes for a work bench.
bdbecker
Iowa
The only reason I went with 3/16" was that I caught a deal on it at work. We had a dozen or sheets that we couldn't use for production so I got it at scrap rate. No reason not to go thicker if you can afford it - if you're buying standard product from the steel yard, you're just paying by weight anyway, so there's not going to be additional savings or cost from one thickness to the other.
BukitCase
Oregon
The 3/16 piece you were quoted weighs 187 pounds; been a few months since I bought steel, but they're asking $1.46 a pound for your piece. Might wanna ask a couple other places if possible, my last price was right at a buck a pound... Steve
I
infinkc
thanks, will call around
