Options to HVAC detached with partial attic truss?
jpcjguy
Richmond, VA
Hi all,
So my plan is a 48x30x12, doors on 48' eave side. See attached. Current design is with 18' of scissor truss for a lift bay and 30' of attic truss. The 30' side will be 10' walls with 2' raised heel on the truss. 9/12 pitch. 2x6 wall construction.
So if I want to heat/cool this building down the road, would it make sense to have 2 mini splits? Small one for the upstairs - area is 16x30 (480 sq ft.) and then a larger one downstairs. Or for the downstairs should I get 2 medium sized? on opposite ends of the garage to help with the scissor truss ceiling area not being the catch all for my heat in winter?
My house is 100% electric, so no gas or propane on the property, currently. Not opposed to having a propane tank behind the garage if that helps cut down on electrical consumption....
Any other reasonable options?
End result, I am trying to determine what future electrical loads I am looking at in order to ensure I size my panel appropriately. I am 200'+ from the house so the main wire is not something I want to upgrade later!
So once I have a plan for the HVAC, I can estimate what that future load would be and then add that to calculations for the rest of the garage.
Thanks!
justinjoyal
Quebec
Before we can help you, we need the following:
- zip code or city/state
- insulation R-value for slab, walls, ceiling
- type of windows and doors and their size
- front door orientation
- what temperature do you want to maintain inside during cooling and heating seasons
- do you plan on opening the doors frequently or not
- what kind of work will be done in there
J
jpcjguy
Richmond, VA
23103 - Richmond, VA
No insulation under 4-5" slab. planning on rockwool - R23 in the walls,R-38 in the ceiling.
1 man door and 2 overhead doors that are 10' wide and 9' tall, no windows
Doors all face the west (very slight north)
Plan is for automotive work, ATV work/storage, looking at putting my free weight gym area in the corner.
As for temperature, in the winter mid-50s and summer 80ish? not looking to maintain it at a perfect 70 degrees. I am ok with moving the thermostat some and hour or two before I go in there.
Hopefully that is enough information- if not ask away. Thanks!
justinjoyal
Quebec
This is the quick load calc I did with the data you provided.
Design indoor cooling temp 78, indoor heating temp 55.
Do you plan on heating only with the heat pump(s) ?
J
jpcjguy
Richmond, VA
justinjoyal - thanks for this info! so to ensure I am interpreting it correctly I need about 14K BTU to cool and 23K BTU to heat it? This is assuming a flat ceiling at 12ft? So I could equal out the scissor truss area that is higher to the 10 ft ceilings on 30ft?
justinjoyal
Quebec
Yeah that’s pretty much it.
However I just realized I missed the 2nd story attic space... should not make a huge difference though.
