Organiser cases (UK)
Brunel
I'm after a quantity of organiser cases (flat multi-compartment boxes). Are there any recommendations for ones that are available in the UK and are cheap?
Harbor Freight ones get a lot of coverage on YouTube, but that's not an option this side of the pond...
PhysicsDude
Dallas, TX
This is probably one of the cheapest options, especially if you're getting a lot of them. The Duratool and Stalwart organizers are identical to each other. They're slightly different from the Harbor Freight organizers, but use the same size bins.
https://www.amazon.co.uk/dp/B017W2Q6PG/?tag=atomicindustr-21
https://uk.farnell.com/duratool/d00417/box-storage-420x335x62mm/dp/1447381
https://uk.farnell.com/duratool/d00...2?MER=bn_level5_5NP_EngagementRecSingleItem_1
You didn't specify in your original post, but if you weren't already planning on using organizers with removable bins, I highly suggest them over the "removable divider" type storage containers.
dutchgray
Dorset. England.
I would second the Racco and Stanley options, both reasonably easy to get and not too pricy, but both decent quality, Sorta case if you want a metal box, if you can find a stockist.
http://www.sortacase.com
Otherwise it is the cheap stuff with whatever brand printed on.
udderlyoffroad
Bristol, UK
I've got the ones as sold by Screwfix and B&Q, that are very similar to the Stalwart ones linked above. They're usually on special somewhere. They're not Sortimo quality, but for the price they're fine.
When I was in the US a couple of weeks ago, I did have a look at the ones in Harbor Freight. These also looked nearly identical, so if nothing else a lot of the ideas for HF storage racks you see on Youtube/Pinterest or wherever will work without major modification. I would have brought one back, but I was already over my baggage limit what with bringing back an abrasive blaster!!
Matt
