dpledford
This is a picture of a new house we are building, the attached garage is 24X24 and the ceiling is 11' high with a 8:12 roof pitch.
I am also building a 24X24 detached garage next to the house. It will be about 30' to the right of the house and approximately 15' back from the houses front. The location is limited because of property line set back, a drainage creek and sewer line easement behind the house.
I am having a hard time visualizing the look of the second garage in relationship with the house. I tried to use Google Sketch up but do not have the time to learn the program.
I will probably receive as many answers one way as the other but suggestions are welcome. The question is should the detached garage have the gable end face the same way as the house garage with the same pitch roof or should the roof side face the road? It's minor thing but I do not want the second garage to detract from the main house.
If the roof faces the road I could drop to a 6:12 roof for a little savings but not much. The contractor building the house is going to frame in the garage using a pole building style and I will finish it off to match the new house. He is using rafters so i should be able to do some modification to the ceiling joists if I later decide on a lift. I have two small Triumphs a six and a seven and at 4 feet high I will not need a lot of modification.
and lowering the price due to economy) the line had to be drawn somewhere. Besides I restored a 1952 Hudson and a 1975 TR6 in a 16X20 yard barn a 2 car garage will be a luxury.
