Osb fasteners
morrillm06
Moultonborough NH
Hey guys,
For those of you with osb interior walls did you nail or screw the sheets up? not sure if either is better or correct but just looking for opinions, thanks
Jon_E
Southwestern Vermont
I like the idea of screws since you can unscrew a sheet if you ever have to deal with wiring issues, or a critter or insect infestation. On the other hand, if you have surface mount wiring, and you are pretty confident that your walls are sealed and dry, then I would simply nail them up. I have the latter, and a leftover box of ring shank coil siding nails, so mine are being nailed up.
jconnor3
Indianapolis, IN
I don't imagine it would matter, but if you go the screw route, get the coated deck screws that are tan. They pretty much disappear.....trust me, I've looked like an idiot trying to remove a few sheets that had me fooled for awhile trying to find the last few holding it down!
hh76
NE Wisconsin
I nailed all except for one sheet that surrounds the electrical panel. A lot quicker, and I'm not too worried about needing access to the cavities.
NUTTSGT
Northern Central Ohio
My garage ceiling I nailed it up with the nailer since I put it up myself. I nailed some of the walls too. There spots in both the house and my garage walls that I knew I needed access so I made sure to screw it up.
Falcon67
Merkel, TX
1 5/8" coated deck screws. Already had a couple of sheets off for sub-surface additions and repairs.
kbs2244
Whatever is easier.
Two men will make it a whole lot faster and worth the extra labor cost.
Jamie V
Atco, NJ
1-7/8" or 2" crown staples if your using 7/16 OSB. There is nothing stronger holding OSB to wood studs.
swamp donkey
Caddo Mills, TX
I've used them on several different houses I have decked and used them for my interior walls on my shop as well. They are almost invisible and make the job really easy.
Jamie V
Atco, NJ
Until someone try's them they will never understand.
My buddy Jay once challenged an inspector when he failed him for using the crown staples over nails. He attached two sheets of OSB to the exterior of an framed addition, one with the crown staples one with nails (the same number of fasteners and same spacing) he then had the inspector rip the sheathing off the studs. The one nailed on came off in one full sheet pulling over the nail heads leaving them all in the studs. The sheet with staples came off the wall too but in like 8-10 pieces. The inspector told him the staples were more then fine to keep using.
PeterT
Toledo Ohio
I used a Senco screw gun, and used 1 5/8" senco screws.
