OSB or Plywood sheathing?
Cetnor851
Mi
Finishing off the lower 8’ of my barns interior and was going to use OSB, only concern I have is when painting is it going to start flaking off like OSB does. Especially long term. Am I better off using plywood sheathing instead? Also with lumber prices right now osb is cheaper 🤷****♂️
iSpark
Coastal SC
I'm putting 3/4 plywood sheathing in my garage. I want the smoother look instead of the chippy look when it's painted.
Plus it's already been priced with plywood.
Crazyjake8493
Upstate NY
OSB is currently 4x the price it should be, and plywood has only gone up marginally, so I would absolutely go with plywood. It'll be a nicer finished look once painted.
I went with OSB because it used to be $8 instead of $32, so the cost difference was worth the aesthetic compromise for me.
sick467
Hughesville, Mo
Plywood! It's nicer, lighter, and easier to work with. It also takes nails and screws much better (for hanging things).
ItsNemo
Canada
The only reason ever to use OSB is because usually it's cheaper. Otherwise Plywood is superior in every single way.
NUTTSGT
Northern Central Ohio
I have OSB on the interior of my garage and the house garage. It's painted and looks fine. I used plywood in the addition of my garage, which does look better.
If prices wouldn't have been crazy, I would have went with a nicer grade than I did. I did pick through the stack when I was buying it.
As far as paint flaking off, why would it ? Some of my osb has been painted almost 20 years and it's not coming off. Do your diligence with either one, good primer and them paint. Cheap out and you'll get what you pay for.
mepstein
I purchased 25 sheets of osb last summer to cover the exterior walls of my workshop. I had 6 sheets leftover from a project of about 15 years ago. The new stuff is junk compared to the older sheets. It works but is lighter in weight, flakes off at the edges and corners and breaks apart much easier. If I had understood the difference before I started, I would have spent the extra on plywood.
nadogail
Coronado, CA
IMHO, The price of OSB can be expected to remain steady, or perhaps even climb, as long as it continues to sell at the present price.
It is simply a "Supply and Demand" issue.
MushCreek
Upstate South Carolina
At the price of sheet goods right now, you might as well cover the walls in hammered gold sheets. I can buy tongue and groove solid wood paneling for the price of OSB. I really need to finish the inside of my shop, but I'm not going to pay the current prices. I simply can't afford to. The cheapest thing I've found right now is 5mm plywood at $17. I'm going to try some on the upper wall where I don't need to hang anything, and see if it stays flat over 16" on center studs.
Sweetcorn
North Central Ohio
If you go with OSB, use an oil based primer and you wont have any problems with it flaking when you paint it. You can cover that with whatever you want, latex included.
Water based primers penetrate into the boards and cause bubbling and flaking.
Copymutt
Colorado
Same here, going on 25 yrs. w/ OSB on garage walls. I suspect in an unheated variable humidity environ it would have trashed itself.
BD1
north side
Definitely plywood. You're only going to do it once.
Showkey
"MEMBER EMERITUS"
Wausau WI
Maybe this topic needs a on going continuous survey vote:
⏹Bare studs
⏹Bare studs insulation showing
⏹Drywall
⏹Plywood
⏹OSB
⏹T1-11 siding
⏹Car siding/shiplap/bead board
⏹Steel panels or siding
⏹Corrugated panels
⏹Galvanized panels
⏹Masonite
⏹Peg board
⏹Vinyl panels
⏹Tile
⏹PVC panels
⏹Slat wall
Then hybrid choices like galvanized on the bottom slat wall on the top will quadruple the choices.
Hank11
Tennessee
Commodity OSB is only a small step above cardboard. I'd choose plywood over osb or if you can find it nearby at a good price some solid wood t&g. Or drywall.
kaymccampbell
Upstate New York
Right now in Halfassed, plywood is actually cheaper. Either way, it's all too expensive for more than small projects. For me, it's time to hunker down and wait it out.
NUTTSGT
Right on Kay. I only bought what I needed because I had an addition going on. However, when I saw Zip was only $2/sheet more, I jumped on the chance to get it before it was gone.
Yeah, I had the extra cost of tape but that was worth it in the whole scheme of things.
John T
I did my interior and exterior in OSB
20 something years ago.
At the time OSB was cheaper.
I had no problem painting it white for the interior and it’s held up pretty good no flaking etc.
The only downside to OSB that I can remember is trying to drive a nail through it.
It’s a royal pain in the azz.
It’s what drove me to buy a nail gun.
Hunt2871
Georgia
OSB is more stable than plywood. It doesn't move nearly as much. But it doesnt hold fasteners as well and is way overpriced currently.....
Bottlecapdigger
Ontario
Another thing that no one mentioned, I always found that OSB, that it really seems to soak up the paint and takes about 4 coats by the time you get a decent sealed and coloured surface. BCD.
