OSB Paint, Seams, & Sanding?
Bigshow0003
Vilas County, WI
I have 4 x 10 sheets of 7/16" OSB hung vertically 24"OC for my interior walls. Based on searches of threads here, it appears two coats of oil based Kilz primer is a good base to start with.
However, prior to that I need to do some prep finish work. A few of my seams didn't align all that great. Any recommendations on filling those voids? Wood filler, drywall mud, or even caulk? I'm thinking I need to slap a little filler in there with a putty knife and do some light sanding.
Any thoughts or recommendations to improve those voids/seams?
Thanks!
Paul_The_Builder
Dallas, TX
When I did my walls I used paintable/sandable caulk for the seams and smoothed it with a putty knife.
I was pretty **** at first trying to get it smooth, but got sloppier as the project went on. When it was all said and done, the paint hides a lot of the imperfections, and its OSB afterall, not like you'll get a smooth drywall-like finish anyway.
motorcycle79
wisconsin
I know a few people who have caulked the joints. I used drywall mud and tape on joints and skim coated everything. I guess it’s how nice and how much time u want to spend.
Showkey
"MEMBER EMERITUS"
Wausau WI
Just did my parts/compressor room.......one coat Kilz primer, two coats of high quality paint.
Light sanding especially on the cut edges.
No filler on the seams. If I was going to fill the seams , drywall compound no tape or chalk ( chalk would get expensive quick). I did chalk the corner seams.
Kaizen
New England
With that much wood I would only use caulk. It’s gonna move and crack hard material.
Stefan S
Texas
I caulked them with acrylic. And then primed and painted
Bigshow0003
Vilas County, WI
Thanks for all the responses. Based on the opinions here and other internet research, I'm leaning towards Dap Alex Flex which appears to be a caulk spackle. Sandable, Paintable, and flexible. Seems like a viable option.
Stefan S
Texas
That’s what I used
mike93lx
Richmond, VA
how are they attached? if screws, i would probably remove the worst offenders and shim them with cardboard drywall shims.
Bolson32
Lake Elmo, MN
I had painted osb on my last garage and had intended to caulk the seems. But to be real honest, I wouldn't even bother. Leave an 1/8" gap for expansion and call it a day. Like someone else said, it's osb and it's never going to look like drywall. You can hide the seems but you're just going to look at the strands anyway.
Sent from my SM-G965U using The Garage Journal mobile app
