mod600
I've got a 32x64x10 pole barn I just put up this summer. Cement work is all done, time to start insulating and sheeting the walls. I will be putting up a divider wall with a service door and overhead door in it. This will allow me to roll sleds, wheelers, etch from storage side (unfinished) to the shop side (finished) Here is my plan of attack:
I will have horizontal purlins on both sides of the poles, the outer the tin is attached to and the inside will have OSB attached to. I'm planning on cutting 1-1/2" white foam to fit inside of both sets of purlins and 6-1/2" batting in between the poles, so I'll end up with a 9" thick insulated wall with an R25 value. I was planning on running my sheets of 1/2" OSB horizontal and running my purlins (2x4s) roughly every 2'. I will be running a 2x6 to mount my electrical boxes in conduit later on and one above my windows to give decent nailer to support for future shelves and/or cabinets. I was also going to cut nailers to fit in between the horizontal purlins and put them right on the poles. Poles are 8' on center, so all 4 sides of the OSB will be backed/supported by a nailer. I was going to use a full sheet at the top, one below that, and a partial sheet at the bottom (10' side walls) Figure the benches, tool boxes, equipment, etc will cover the bottom seem. Some guys run their sheets vertically, do they put in vertical nailers to support the seams, or is this not neccessary? I haven't gotten into it too far, more thinking than doing at this point. My plan in my mind makes sense...but I could be missing something...? Any thoughts and suggestions...
Thanks!
mod600
Thanks!
mod600
Sorry - that does read real picky!
